Old 06-19-2010, 03:41 PM
tudorvintiloiu's Avatar
tudorvintiloiu tudorvintiloiu is offline
Default Re: Bearing Chain Tensioner
You have to shorten the chain. Did you do that already? Look for the master link which allows you to undo the chain, then, using a chain breaker, adjust the length of the chain, and then use the master link again to close it up. It's easy. Just make sure you don't make it too short. Measure twice and cut once!
