Old 06-19-2010, 01:21 PM
Vfalpha-1's Avatar
Vfalpha-1 Vfalpha-1 is offline
Default Re: New to the forum
ok well im headed off to home deopt for the bit and kragens for gasket material i want to replace the head bolts with something a little stronger , so would all thread rods cut to size work ? also since the engine is going to have more power should i worry about using the stock sprocket , wouldnt the rpms be a little on the high side for these engines ?
and im also going to balance the crank as best I can
