Old 06-18-2010, 04:11 PM
CoastalCruiser's Avatar
CoastalCruiser CoastalCruiser is offline
Default Re: springer forks+breaks...what can be done?
Side pull caliper or drum is no problem. Discs won't work because of the movement of the fork. If you want disc brakes on the front you need a solid or telescoping fork. V-brakes are possible but you have to figure out how to mount lugs, though I seem to recall a post on here referring to some pre-lugged custom jobs. I hope that helps.
