Old 06-16-2010, 11:22 PM
corgi1's Avatar
corgi1 corgi1 is offline
Default Re: Clutch arm questions
There were2 springs,the larger one is a heat shield to keep the clutch cable from melting on the cylinder,,,,the smaller spring goes between the clutch arm (over the cable its self)and the place where the cable housing stop is,,,,,pull the free play out of the clutch lever while sliding the cable through the end of the clutch arm,(compressing the smaller spring)and tighten the (brass?)cable stop no the cable(the clutch arm should be at the 5:00 position at this point and there should be little play(pincil lead width) play left in the clutch arm,,,,,,,,,,,squeeze the clutch lever on the handel bars and see if it works
