Old 07-09-2008, 06:36 AM
Default Re: Idle Screw Adjustment
Originally Posted by stude13 View Post
hi; you are right 4 1/2 out until later. it does not set the idle, it is adjusted at the top at the cable end. much more knowledge here. good luck. mitch
You are incorrect sir!
The screw is for idle speed adjustment ONLY. They tend to be different lengths, so if you have it at one turn and it idles good, leave it there.
The adjuster at the top of the carb is for taking the slack out of the cable. You should adjust it until there is just a tiny bit of free play in the cable housing, then adjust the idle speed screw at the side of the carb.
