Old 06-12-2010, 12:42 AM
Aqua Aqua is offline
Default Re: Rear wheel locks when disengaging clutch, no engine start is this normal?
Ok pardon for the dumb question but is the sprocket supposed to lock like that at low or no speed when the clutch is out?
Reason I ask is when I first installed the clutch cable, the clutch was stuck and would not allow the sprocket to turn even when the clutch lever was pulled all the way over, so after searching these forums I went into the star nut side and loosened it a bit, and wiggled the big plate circle thing so it released when the lever was pulled (seemed like it was just stuck from sitting or something).
I assumed from the instructions when the clutch is out, the sprocket is locked and when it is in, the sprocket can move right?
