Old 06-03-2010, 07:39 AM
metalliatic's Avatar
metalliatic metalliatic is offline
Default Re: thick or thin base gasket?
Originally Posted by Junster View Post
Ok I tried no base basket and could not keep a good seal. A good seal at the base is vital. I bought a base gasket but I used it for a pattern. The best I've found is the 1/16" thick charcoal black garlock. Very durable, heat resistant, just the right thickness. It re-times the ports just slightly higher. I have a slant head and my motor has great compression. Along with shift kit, tuned pipe, CNS carb I get about 42mph on a flat road with no wind.
so is that thicker then the original gasket? what about no gasket and just use silicone to seal it?
its not how fast you go... its how you go fast
