Old 05-31-2010, 05:56 PM
mapbike's Avatar
mapbike mapbike is offline
Default Re: Tcams unfortunate event
That adapter just needs to be drilled /tapped and then put a Heli coil in it and you will be good to go with it, and as was said by others.... Loc-Tite is a must on these bikes, I learned that the hard way as well, lost engine mounting studs and other bolts, these things have just the right kind and amount of viberation to knock all kinds of thing loose. good luck with your ride hope you can get it all fixed back up.
