Old 05-27-2010, 12:59 PM
GearNut's Avatar
GearNut GearNut is offline
Default Re: How does the killswitch work?
The stock kill switch shorts out the signal from the mag to engine ground.
IMHO, if any switch really needs to be used, it should be an on/off toggle switch in line with the blue wire. That way you are just disconnecting the signal going to the CDI unit rather than shorting out a component.
"It's a chinagirl. It's a sometimes fun little engine that often will break your heart. It's disposable.
Does not come with a fortune cookie."
