Old 05-26-2010, 09:44 PM
Cabinfever1977's Avatar
Default Re: stupid threaded rods
I wouldn't use anything under the engine mounts.
Rubber and even tape will wear out over time and cause the mounts to loosen, and on the rear mount gas from the carb will drip onto the rear mount and anything under it, rubber or tape will get eaten alive and make a sticky mess.
If you need to get rid of vibrations at high rpms get a smaller rear sprocket to lower rpms or keep your speed down.
