Old 05-26-2010, 02:09 PM
Terry Blow's Avatar
Terry Blow Terry Blow is offline
Dealer & Custom Builder
Default Re: Blow By U First Production Build Felt Twin
I have one more thing to say about this drill and tap issue when you are tapping a hole in steel with the metal thick enough the tap will bind in the metal at that point you have to turn the tap back wards before you can go for-wards again if you do not you will break the tap. If how every your tapping and the tap dose not bind you will not need to reverse your tap. Witch is the very thing that happened with the Felt Twins top tube now an experienced person that has lots of experience with type of skill will tell you the same thing.
