Old 05-20-2010, 03:18 AM
dag_29307's Avatar
dag_29307 dag_29307 is offline
Default Re: Combo Brake and Clutch Lever. Any Good?
personally I have the dual brake lever and the clutch solo. I just don't trust that whole set up. if you use two fingers to "pull" the brake and use your thumb to "push" the other lever, you don't have a very good handle on things then. No pun intended. I mean you are exerting force in two directions at the same time. When both actions are equally important. In a crisis are you really going to be able to control everything at once? I do not have experience with this set up. I just personally don't trust it. I am sure someone here is using it and will be able to give their opinion.
Just remember...Opinions are like a**holes, Everyone has one. Some just stink more than others.
Hope it Helps. I am also a proud member of the 20 MPH. club
