Old 05-19-2010, 04:02 AM
matesrates matesrates is offline
Default Re: Horn connected to engine??????
Originally Posted by BarelyAWake View Post
Finding a 6v horn isn't that tough - but finding one with as low an amperage/wattage as to not immediately shut off the engine might be a bit tricky. Loosing power would be fine - but I suspect it'd act as a kill switch & defeat the purpose.
I've a vintage headlight with a horn built in, designed for a mere 3v instead of 6 it might work... but I've a generator hub so I've not tried it... for this I'd suggest batteries (headlight horn combo is common) or even an air horn like city of angles suggested *shrug*
Them generator head lights and tail lights combo
Would a mini horn work off this instead of lights??
This only creats very small power??
I was thinking about putting a small 6 volt motorbike battery
But i don't want to recharge it every time it goes flat....
So connect it to white wire????
But then i have problem of to many amps in the battery might do damage??
What do you think of this???
