Old 05-16-2010, 02:59 AM
Patr1ck Patr1ck is offline
Default Re: Shift Kits?? Confused =\
Originally Posted by Cabinfever1977 View Post
If you ran the drive threw the peddal sprockets starting on the left side, the peddals would turn with the motor,even with a freewheel. but it would work if you removed the peddals and put foot pegs on the bike, would only be good in states that do not require no peddals.
The engine needs a direct drive to the freewheel then to the rear sprocket on wheel and the freewheel on the peddal sprocket separates the peddals from the drive from engine. You could move everthing to the left side of the bike but would require a few hundred dollars worth of parts.
Could a freewheel bearing be added (like in the shift kits) to one of those tandem bike crank assys as they have a sprocket on each side? If not, does anyone feel like designing one?
