Thread: lowend bog
Old 05-06-2010, 06:53 PM
motorhead419's Avatar
motorhead419 motorhead419 is offline
Default Re: lowend bog
Originally Posted by beentryin View Post
i have a 66 gt5 skyhawk and ive run alomst a gallon thru it,i ported both ends.nothched the piston to clear the intake port,and it bogs on lowend till i hit around 15mph then it startd screaming,or if give it a little choke it seems to pull better on lowend but loose top end,or if i take the baffle out it has tons of low and top end?
Lower the jet needle clip which will raise the needle and richen the mixture...This is good for 1/4 -3/4 throttle adjustment fine tuning.
