Old 07-02-2008, 10:02 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: accidentally solving a problem
sometime the brass nipple that the fuel line attaches to isn't tight and it will seep fuel very gentle tighting will help if its loose. The fuel line also likes to leak on that brass fitting as well I use stainless steel safety wire as a hose clamp to seal that off it hard to get a regular hose clamp on that small line.
Does the wire work you ask well I have a home built airplane and that is what I use on the fuel tanks sight glass clamps and in 23 years no leak.
