Old 04-30-2010, 01:43 PM
2door's Avatar
2door 2door is offline
Default Re: Cheap Rubber Motor Mounts
Originally Posted by AaronF View Post
You may want to check Manics custom fitted motor mounts out @ $43.00 shipped its a great deal.I've had them installed for about a week now with the rubber isolators that fit into the machined grooves no problems here. If I may,here is a picture of his new designed mounts.
I believe if you check with Jim he'll tell you that he doesn't use rubber in his mounts but a very hard polyurethane material. He has done a lot of experimentation and found that rubber didn't work.
