Old 04-30-2010, 10:05 AM
2door's Avatar
2door 2door is offline
Default Re: Cheap Rubber Motor Mounts
Forget it. The engines should be mounted solidly to the frame. In addition those rubber isolators you are thinking of using are for light duty applications such as fans and such. They will not stand up to the vibrations produced by a 2 cycle gas engine. Rubber mounting these engines has never proved to be successful and the thicker the rubber the more problems you'll make for yourself. Do what works; mount the engine the way it was designed to be mounted. These are not Harleys or Hondas. Forget the rubber mounts.
