Old 04-25-2010, 10:24 PM
mapbike's Avatar
mapbike mapbike is offline
Default Re: Bucking bar to camshaft problem.
Go and get you a grade 8 bolt that is 5/16" in dia. and 3-4" long cut the threads off and then messure up the bolt for the correct length and cut it again, grind a slight beveled edge on both ends and put some good high pressure moly grease on each end and you should be good for a long time before having to replace the bar or adjust the clutch cable.
Hope this helps...
