Old 07-01-2008, 09:28 AM
Wheel Rush Wheel Rush is offline
Default Re: Whats With My Gas Cap
BikeGuy 31,
The gas cap has an extended cylinder in its center, I am taking it that you are saying to drill a, "tiny hole", just into the surface of the cap, if I do this the cylinder that holds the pressurization spring, will not be effected correct ?
Do you have any idea why the pressurization cylinder assembly does not work well enough to prevent this evaporation in the first place ?
My guess, . . is that there is not enogh pressure on the rubber washer that seals it when it is turned tight ?
