Old 06-30-2008, 01:40 PM
Wheel Rush Wheel Rush is offline
Default Re: Squeal in Front Chain Sprocket
OK, I put a few drops of multi purpose into a straw and dropped it in,
I than added a finger tip full of lube stuck it in the hole a refit the post bolt. I'll do the gears as per your instructions, ("each tooth"), I assume this is enough on the large gear to lub the small gear.
The inside cover has some ever so slight indication that something may have been spinning while touching it. However it does seem microscopic.
Well. I'll adjust the clutch and give it a try, we'll see, thanks much !
