Old 06-29-2008, 08:56 PM
Wheel Rush Wheel Rush is offline
Default Re: Squeal in Front Chain Sprocket
If you are speaking of removing the plug and turning by hand, "using the kit wrench", OK, but this occurs mainly in neutral, wait a minute, I know it is when the chain is moving in neutral which means the rear wheel is moving, correct ? this then I think applies to coasting correct ? Well I have it apart now I'll put it back together and check again, as soon as you tell me exactly where to squirt the oil.
