Thread: Crack in Carb
Old 06-29-2008, 01:09 PM
MarcPhotoMan MarcPhotoMan is offline
Default Re: Crack in Carb
Ok so as many of you know I have been chasing a very small vapor leak. After sealing up the cracks in my carb, which i could only find via my digital camera and photoshop and lot of evidence that someone tryed to fix it before i even owned it.
Just venting a little
Any way I think it's fixed thanks to JB Weld.
but now it is Idling high, I have to screw the idle screw all the way in the idle become lower, when i let the screw out the idle is higher.
I am 100 feet above sea level and it is on the needle second from the top.
Yes i did test with wd40 and it does not stall,
Just one question when you say bog down you mean the idle would change and almost stall?
