Thread: need some help
Old 04-13-2010, 02:54 PM
NunyaBidness's Avatar
NunyaBidness NunyaBidness is offline
Default Re: need some help
It sounds like your motor is not actually starting. When you have no spark it will sound much like you're describing. Take the spark plug out and reattach the plug wire. Ground the plug against your motor as you turn the rear wheel, if you don't see a spark then you have almost found the solution. If there is no spark it could be because of your plug, plug wire, CDI or magneto.
Make sure you have spark first and if not we will see if we can help you find out what exactly is the problem.
