mapbike
Many of you guys out there may have already used this product or one simular, or may have what you believe to be a better way of fixing a broken Aluminum part, but if there are any more guys like myself that dont have a Tig set up or a Mig set up for welding Aluminum here is a great product that will fix most of what ails you if you need to make a simple repair to an Aluminum part like the clutch lever housing or some stripped threads in the block, all you need is a clean stainless steel brush and aPropane Torch and you are set to repair Aluminum and it is a repair that is stronger than mild steel which is much harder that the parent Aluminum material, The product is called "Alumiweld" I bought mine at my local Tractor Supply Store but you can get it online direct, I've been using the stuff and it works great.
Heres the link to their site: Aluminum welding repair rods, weld any aluminum metal by using a Propane Torch - Alumaweld
Hope this helps someone out there.
Shan
Shan
