Old 03-30-2010, 12:03 PM
aspireonescs's Avatar
aspireonescs aspireonescs is offline
Default Re: stock carb question
i just use a rubber band that i wrap around the choke lever then the other end goes to a nut on my front derailur, but if you find that your not using the choke at all then just remove it. you can always put it back on if ya ever need it, i never need my choke but i keep it on there just cause lol, but try the rubber band it helps alot :0
