Old 06-26-2008, 04:24 PM
thatsdax thatsdax is offline
Default Re: Things falling off mb
Yes..If you use loctight, and you bought your engine from me, you will void your warranty. You will ruin the motor. First of all, loc tight is not necessary , . I have done over 300 installs with thousands and thousands of miles, and never had to use loctight. First of all, as your motor and bike breaks in, you will need to tighten your nuts and bolts down more. Loc tight will not aid you or help in this. Also, if you use the wrong loctight, you will prevent the tightening or removal of nuts and bolts. If you have a concern with a nut getting lose, go to a nyloc or double nut them. If you use glues, you will ruin those connections or at least make those connections hard to deal with or maintain. thanks.. Enjoy the ride..
