Old 06-26-2008, 11:44 AM
MrLarkins's Avatar
MrLarkins MrLarkins is offline
HS Math Teacher
Default Re: How to Bob the end off of a Cable w/o Spurring It
Originally Posted by Bikeguy Joe View Post
Just make sure you remove the cable from the housing before cutting either.
In a pinch, you can cut the cable or the outer with a bench grinder. Remove the cable and hold it at a 45 degree angle and rotate it then do the same with the outer....smooooth.
You can also cut the cable with a cold chisel.
the cable is not shielded where the cut will why not use wire cutters?
