Old 03-23-2010, 06:59 PM
broHSI broHSI is offline
Default Re: Will a 24 tooth work?
Bikewithamotor, what is the diameter of your 24 tooth sprocket?
Originally Posted by Venice Motor Bikes View Post
Here's a question... How much do you weigh??
If your real skinny like Baird (130 lbs), you can run something small like a 30T.
Baird is running 24" wheels which makes a difference of over 3 MPH at 7000 RPM
his motor is hotted up and much faster than stock....
Stock motor with 26" wheels should not go lower than 35/ 36 teeth on fairly flat ground
Go bigger if you are heavy and have a lot of hills
Altitude will decrease your performance too
24 tooth sprocket will give you a top speed of 55 MPH at 7000 RPM
which your engine will never pull
