Thread: 80cc Mystery
Old 06-23-2008, 09:41 AM
misteright1_99's Avatar
misteright1_99 misteright1_99 is offline
Default Re: 80cc Mystery
Originally Posted by misteright1_99 View Post
In this post Norman shows you the internals of the carb. You need to read it an familiarize yourself with it then you might want to try moving the clip ONE notch and riding your bike and see what you think. And then MAYBE try another slot and TEST RIDE ETC. Looking at that spark plug I think you are running lean so you should start with moving the clip DOWN 1 slot to increase fuel to air mixture....
Originally Posted by MrLarkins View Post
i also moved the 'c' clamp to the lowest position in the carborator...isn't that suppose to give the most oxygen in the mix? i don't think i'm getting maximum combustion...lots of oily black on plug...and i mixed 4oz 2 cycle oil with 1 gallon gas, that's the right mixture, right?
no, someone told me to move it down i did, then i went down 2...when i get home (at work now, goofin off ) I move it up and post back
here's the guy MISTERIGHT2_99!!!
Read the first paragraph one more time CAREFULLY!!!!!!!
"No such thing as a stupid question, just a stupid answer"
48cc Grubee Starfire Round Head......
