Thread: 80cc Mystery
Old 06-23-2008, 09:07 AM
MrLarkins's Avatar
MrLarkins MrLarkins is offline
HS Math Teacher
Default Re: 80cc Mystery
Originally Posted by misteright1_99 View Post
You are definatly lean... Look at the pic of the spark plug, Might want to raise the needle in the carby (lower the clip) one slot......Parts all look ok though. Also when you put the piston back in the cylinder make sure you line the opening of the rings up with the little pins in the grooves...
8oz @ 20:1 = 160oz of gasoline 128oz = 1 Gallon So 8oz of oil to 1 Gal and 1qt of Gasoline
Any QUALITY oil..... I use Amsoil Sabre....
here's the guy MISTERIGHT2_99!!!
