Old 03-02-2010, 03:53 AM
rkorson4209's Avatar
rkorson4209 rkorson4209 is offline
Default Re: JNM Damp-Pro AnyOne used these yet?
Originally Posted by BarelyAWake View Post
Yarp - alla that's tru (cept the heat), and one advantage of that "kit" is ofc not havin' to do anythin' like cutting to fit... mebbe... but in all honesty just about anything ya do would be an improvement - I doubt this (the fancy kit) is any better or worse than any other solution.
I just don't want anything "stuck" to the outside of my engine, as much as I ride - it'd never last.
BTW with the undercoating and the flower nut, that's one advantage of a soft, spray-on coating - coat the inside of the cover as thick as ya like and even if something contacts it, it "wears away" leaving a perfect fit w/o hurting anything, any residue has no effect (doesn't manage to get into the clutch). If yer picky - a lil acetone and a toothbrush will clean up the "smear" on the flower nut.
I used the spray on undercoating and i gotta say it is a big improvement. Easy chaep, and you can really put it on thick. Gotta get 3M tho. then i like to spray dupli color truck bed liner on the outside. nice look with the texture very durable, and it says it reduces sound, so i figure reduceing it from both sides is better, seems to be really quiet now.
