Old 02-16-2010, 06:39 PM
onefast68 onefast68 is offline
Default Re: stock pipe vs barry pipe vs custom
well i cut up the pipe and and welded on the get it the right length i had to leave some of barrys bigger pipe and welded the muffler to it..inside barrys pipe was some washers right at the transition from the little to big pipe...i used a long drill bit and opened up the hole in the washers as much as i now the exhaust goes through the little pipe hits the washer and into the bigger chamber and then through the actually sounds pretty good and revs real is a pic,i will build a mount strap this week as well.
