Old 02-06-2010, 05:06 PM
warner warner is offline
Default Re: Universal Tachometer
Originally Posted by Vistaman73 View Post
That looks like the same thing made by a different brand. How often does it update? 2.5 Sec? thst seems too slow. if it does, how do like it?
I'm using the one Staton sells, too (SenDEC). There IS a slight delay....but unless you are used to seeing a bouncing tach needle, it's adequate. It tells you what your cruising RPM is...and you can see how high you're revving and whatnot. And doubles as an hour meter, so that's a nice bonus. Good unit. Simple to install. You won't regret getting one.....very slick little meter.
