Old 02-05-2010, 02:26 PM
Dave31's Avatar
Dave31 Dave31 is offline
Default Re: Suspension Seat Post That Doesn't Wobble?
Originally Posted by fairracing31 View Post
The seat tubes have a channel slotted completely through them for the bolt. This eliminates the seat from wobbling and spinning and to keep the seat from lifting up. Once the bolt is through just cut the head off and grind down so it all slides in the seat tube of the frame.
What I meant to say was the 7/8 seat tube has a channel slotted the same width as the bolt, the 1" has a hole drilled for the bolt.
It's hard to see but what I am pointing out is the bolt shaft that goes through the 1'seat tube and through the channel of the 7/8 tube that is inside that cannot be seen.
