Old 02-03-2010, 02:04 AM
AaronF's Avatar
AaronF AaronF is offline
Default Re: At a Crossroads...
I think your first step would be to spend the money on a new bike for better clearance and results..Not only that,you said your engine leans? Your motor needs to be mounted solidly against the frame tubing,that motor could possibly shift on you while riding from all the torque and cause future problems.The carburetor at a slight tilt depending on how much of a tilt its on shouldn't cause any problems if slightly angled.A 38T or 36T Sprocket should fit your needs pretty well.
