Old 01-26-2010, 08:24 AM
Elmo's Avatar
Elmo Elmo is offline
Default Re: drill your own sprocket?
Originally Posted by beerbattered View Post
Is it possible to buy a sprocket without holes? I'm going to mount it on the disk mount and I don't think I have to have an adapter for any other reason so why not eliminate it by drilling proper holes?
Check out Azbills threads. I bought a wheel from him that is set up that way. It appears that he took a regular sprocket and drilled it to match the holes on the disc brake rotor and cut the center out. PM Azbill for more info.
All times wasted wots not spent ridin. Get a bicycle. You will not regret it. If you live. Mark Twain
