Old 01-20-2010, 03:53 PM
Mac's Avatar
Mac Mac is offline
Default Re: these things suck
Check the mag connections(to the coil) make sure there not too close to the frame (Arc when pedaling) that'll kill the spark. A note to save you some trouble(I ignored this advice for the "test" run) AND I paid the piper... do something to secure the Chain Tensioner/roller to the frame, weld or drill a hole and put a loctite screw into frame(thru tensioner), it is under a huge load during starting or engine "braking", when it rotates in (due to the cantilever force applied) an it WILL rotate in, Right in to the spokes...
Happened to me!
