Thread: sproket wobble
Old 01-15-2010, 07:58 PM
Cabinfever1977's Avatar
Default Re: sproket wobble
When you tighten the bolts on the sprocket you have to tighten the bolts in a crisscross patern(like lugnuts on a car),which is tighten a bolt(but not all the way yet) then tighten a bolt across from that one,then go to a oposite side of the sprocket and do the samething,keep doing that all around the sprocket,keep checking for wobble while youre doing that,then if its good go all around and finish tightening all the bolts in a crisscross patern.
