Thread: Broken studs
Old 01-09-2010, 05:53 PM
2door's Avatar
2door 2door is offline
Default Re: Broken studs
Originally Posted by Evan View Post
Should i heat before trying to remove?
With the blue label Loctite usually heat is not necessary. That's the beauty of it. It holds but does not require heat to break the bond. The threads will be tight all the way out but once you get them started they should come. Good luck; keep us posted.
