Old 01-04-2010, 09:21 PM
bluenosegoat's Avatar
bluenosegoat bluenosegoat is offline
Default Re: Hub and sprocket adapters
I must be really close to perfect on the sprocket/rag joint as i have never thrown the chain and I have about a 120 miles on it already. I do notice how ever that the chain gets a little tighter in one spot when i rotate the sprocket. I like the hub adapter especially to be able to change ratios so much easier. The rag joint was the biggest pain of the whole process. I will call Manic tomorrow for sure. What is the spoke flange measurement asked for? I also googled my hub and got every spec on the hub but the diameter of the hub center itself! I'm not sure if i trust my caliper to .002 as I have to convert from 32nds.
