Old 12-31-2009, 12:52 PM
wheelbender6's Avatar
Default Re: My Build has started :) Another Cranbrook
Most members run 20:1 premix during breakin.
Ditto on the front brake. Get one. You can run a bmx brake through the fender hole in the fork.
Use any good grease on wheel bearings.
I use 90wt gear oil on my chain, because i have a lot of it.
Fuel line supplied with the kit worked fine for me. They should probably be replaced annually, since they harden over time.
“You're only young once, but you can be immature as long as you like" -Unknown
