Thread: Rag Joint
Old 12-20-2009, 01:58 PM
2door's Avatar
2door 2door is offline
Default Re: Rag Joint
Like Joe, I was a little confused about his description of the problem too but you might be right. In a case like this we would sure benefit from a photo. I don't think I've ever seen a situation that the rubber was too thick to allow the sprocket to fit over the hub. I have seen rubber that was cut at an angle so if installed it would assure a wobble due to the uneven thickness. I hope he comes back with some more information.
