Old 12-19-2009, 01:35 PM
Maxvision's Avatar
Maxvision Maxvision is offline
Default Re: What kind of rear sprocket needed for a NuVinci hub with SBP shift kit?
Originally Posted by Cabinfever1977 View Post
you will want to use a freewheel. if you use a standard sprocket your peddals will turn all the time, even when coasting.
Most hubs that you buy will not come with the freewheel sprocket and you need to buy it separately, and they usually tell you which one to buy.
The SBP shift kit comes with a freewheel for the pedal sprockets.
