Old 12-16-2009, 10:20 PM
Mikey DEEEE Mikey DEEEE is offline
Default Re: Double intake fuel valve
Originally Posted by Finfan View Post
Might be simpler to have a valve on each tank then run them to a "T". From there they can feed through the filter to the carb.
Edit: You would have to always run the higher tank empty first since liquid will attempt to seek the same level. You couldn't have both valves open at the same time.
Where can i buy one?
