Old 12-15-2009, 02:34 AM
AaronF's Avatar
AaronF AaronF is offline
Default Re: Has anyone tried these thumb throttles?
The throttle has a very nice response,easy,no slipping and doesn't wear out the thumb.
Rot,It depends how your handlebars are setup,how much room etc.Main thing is adjusting for easy access and control..You could use a shifter but you'd have to grind a little off the cable end for a proper fit inside the shifter mechanism or make your own with a strong gear cable.
