Old 12-14-2009, 04:38 PM
xlite xlite is offline
Default Re: different way to change fuel/air mix?
Originally Posted by Bikeguy Joe View Post
I will add that the float adjustment is as touchy as many other things and a heavy hand will do more harm than good. With the "float method" you are adjusting the overall level tipped, not tipped, ect.
True, it is touchy. Too high and it leaks, too low and it starves. I don't think it's any more risky than shutting your fuel cock off or forgetting to turn it on though. IMO these engines aren't as sensitive to damage running lean as motors with tight clearance.
One thing I do suggest. Carefully measure the positions before adjusting so you can always get things back in case mixture wasn't your problem.
