Old 11-22-2009, 03:49 PM
2door's Avatar
2door 2door is offline
Default Re: Hand grip removal- What's your method?
Originally Posted by Venice Motor Bikes View Post
This for all you foolios to go out & try right now!!
This is the easiest way on earth to take a grip off!!!! No comrpessed air, no WD40, no water & screw driver or spokes........ just a wrench & a hammer & it's off in 3 hits!!!!!!!
This works on 90% of all grips out there; the only grips it won't work on are super soft (super sticky) rubber grips...
Seriously!!! go out to any bike right now & try this!!!
(& if you can't remove it in 3 hits; you're hitting it like a girl!!)
Ahhh, thanks a lot, Venice...You owe me a throttle/kill switch, a clutch lever, two brake levers and a rear view mirror mount. That hammer method is a little rough on things...
