Old 11-21-2009, 08:16 PM
2door's Avatar
2door 2door is offline
Default Re: Hand grip removal- What's your method?
Originally Posted by saulsvilleb View Post
if you use wd-40 you will have time getting them to stick when you put them back on, if I dont have air I use hair spray to remove and to glue them back on
Not true. The WD-40 will not keep the grips from holding when you reinstall them. I've done numerous sets of grips. In fact it makes reinstallation easier and holds the grips tight afterwards.
