Old 11-19-2009, 02:13 PM
fall_down_stand_up's Avatar
fall_down_stand_up fall_down_stand_up is offline
Default Re: Im going to run a NGK B5HS spark plug....
Originally Posted by BarelyAWake View Post
You runnin the stock carb ona 66cc? If so - is it the old style or the new one with the second fuel petcock on it?
Its the factory carb(new in the box) I just put on off one of my new Raw kits....Its has a much larger throat (slide)than the Thatsdax carbs I was running....
IF I CANT FIX IT,IT ISN'T BROKEN!....ummmmmmm so I thought....
